[GRASS-dev] 6.3.0 backport question
Glynn Clements
glynn at gclements.plus.com
Thu Nov 15 18:46:17 EST 2007
Markus Neteler wrote:
> >> I have seen a set of fixes in the CVS which haven't been backported
> >> yet. So far I didn't figure out the magic line to push a fix
> >> from HEAD to release branch.
> > This normally works (from the branch):
> > cvs update -j HEAD <filename>
> > cvs commit <filename>
> I have tried this in
> macosx/app/
> and then run 'diff -ru ...' on it against HEAD. They are not identical.
If I do:
cd /usr/local/src/grass/cvs # HEAD
cvs update
cd /usr/local/src/grass/6.3 # releasebranch_6_3
cvs update
cd macosx/app
cvs update -j HEAD
diff -rq {6.3,cvs}/macosx/app
the only differences are in the CVS/* files (Tag and Entries).
It may be worth updating the directories with "cvs update -A" and
"cvs update -r releasebranch_6_3" respectively to ensure that you
don't have any incorrect sticky tags.
