[GRASS-dev] nasty bug in v.what.rast (CVS ~ 2 weeks ago)
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Nov 15 19:10:56 EST 2007
On Thursday 15 November 2007, Dylan Beaudette wrote:
> # setup region
> g.region rast=elevation.dem
> # create a point
> echo "597843.375|4920255.640625" | v.in.ascii out=testing
> # add table and make a column for loading elev into
> v.db.addtable testing
> v.db.addcol testing col='elev double'
> # read elevation.dem at the point:
> v.what.rast vect=testing rast=elevation.dem col=elev
> ## Ack! what does this mean?
> WARNING: Raster type is integer and column type is float
> WARNING: More points (2) of category 1, value set to 'NULL'
> 1 categories loaded from table
> 1 categories loaded from vector
> 0 categories from vector missing in table
> 1 duplicate categories in vector
> 1 records updated
> 0 update errors
> ## check result: missing the elevation.dem value
> db.select testing
> cat|elev
> 1|
> ... it looks like this error is being thrown from some kind of caching
> effort:
> # from v.what.rast/main.c:
> for (point = 0 ; point < point_cnt ; point++) {
> if ( cache[point].count > 1 ) {
> G_warning ( _("More points (%d) of category %d, value set to 'NULL'"),
> cache[point].count, cache[point].cat );
> dupl_cnt++;
> /* category exist in DB ? */
> cex = (int *) bsearch((void *) &(cache[point].cat), catexst, select,
> sizeof(int), srch_cat);
> if ( cex == NULL ) { /* cat does not exist in DB */
> norec_cnt++;
> G_warning(_("No record for category %d in table <%s>"),
> cache[point].cat, Fi->table );
> continue;
> I am using CVS from a couple weeks ago.. could this have been recently
> introduced / fixed?
> I will download the latest CVS and report back.
> Cheers,
> Dylan
Sorry for the spam, it looks like the bug is related to this:
cvs diff -r 1.26 -r 1.27 main.c
Index: main.c
RCS file: /home/grass/grassrepository/grass6/vector/v.what.rast/main.c,v
retrieving revision 1.26
retrieving revision 1.27
diff -r1.26 -r1.27
221,235c221,228
< i = 1;
< while ( i < point_cnt ) {
< if ( cache[i].cat == cache[i-1].cat ) {
< cache[i-1].count++;
< for ( j = i; j < point_cnt - 1; j++ ) {
< cache[j].row = cache[j+1].row;
< cache[j].col = cache[j+1].col;
< cache[j].cat = cache[j+1].cat;
< cache[j].count = cache[j+1].count;
< point_cnt--;
< continue;
< i++;
> for (i = j = 0; j < point_cnt; j++)
> if (cache[i].cat != cache[j].cat)
> cache[++i] = cache[j];
> else
> cache[i].count++;
> point_cnt = i + 1;
reverting to this version fixed the problem for me. I am not sure how to
interpret what the changes implemented from 1.26 -> 1.27 are doing, although
it looks like some kind of optimization. Glynn? :)
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
