[GRASS-dev] nasty bug in v.what.rast (CVS ~ 2 weeks ago)
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Nov 15 20:29:17 EST 2007
On Thursday 15 November 2007, Glynn Clements wrote:
> Dylan Beaudette wrote:
> > Sorry for the spam, it looks like the bug is related to this:
> > cvs diff -r 1.26 -r 1.27 main.c
> > Index: main.c
> > RCS file: /home/grass/grassrepository/grass6/vector/v.what.rast/main.c,v
> > retrieving revision 1.26
> > retrieving revision 1.27
> > diff -r1.26 -r1.27
> > 221,235c221,228
> > < i = 1;
> > < while ( i < point_cnt ) {
> > < if ( cache[i].cat == cache[i-1].cat ) {
> > < cache[i-1].count++;
> > < for ( j = i; j < point_cnt - 1; j++ ) {
> > < cache[j].row = cache[j+1].row;
> > < cache[j].col = cache[j+1].col;
> > < cache[j].cat = cache[j+1].cat;
> > < cache[j].count = cache[j+1].count;
> > < point_cnt--;
> > < continue;
> > < i++;
> > > for (i = j = 0; j < point_cnt; j++)
> > > if (cache[i].cat != cache[j].cat)
> > > cache[++i] = cache[j];
> > > else
> > > cache[i].count++;
> > > point_cnt = i + 1;
> > reverting to this version fixed the problem for me. I am not sure how to
> > interpret what the changes implemented from 1.26 -> 1.27 are doing,
> > although it looks like some kind of optimization. Glynn? :)
> Yes, it's an optimisation (from O(n^2) to O(n)), but with an
> off-by-one error which effectively duplicates the first entry.
> Try this:
> --- vector/v.what.rast/main.c 22 Oct 2007 15:23:41 -0000 1.28
> +++ vector/v.what.rast/main.c 16 Nov 2007 00:31:01 -0000
> @@ -219,7 +219,7 @@
> G_debug(1, "Points are sorted, starting duplicate removal loop");
> - for (i = j = 0; j < point_cnt; j++)
> + for (i = 0, j = 1; j < point_cnt; j++)
> else
> Oddly enough, Markus actually tested this before it was committed, but
> only for timing, not results (see "v.what.rast speedup" thread from
> around Oct 22).
that did the trick. thanks.
That GRASS test suite is looking more and more important...
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
