wingrass: dbf errors [was: Re: [GRASS-dev] select issue with wingrass]
Moritz Lennert
mlennert at club.worldonline.be
Sun Nov 18 18:35:49 EST 2007
Michael Barton wrote:
> Also, we're still getting the dbf.exe error. Unfortunately, we cannot copy
> anything from the error message box or even make the box bigger so as to
> show more of the error details. Is there a way to log this to send to you,
> as it is quite long?
> Interestingly, we are getting the *same* error produced by v.in.db when
> running r.contour.
Both v.in.db and r.contour work for me.
Could you give me exact command lines and the data you used ?
Moritz
