[GRASS-dev] select issue with wingrass
Glynn Clements
glynn at gclements.plus.com
Mon Nov 19 11:04:28 EST 2007
Michael Barton wrote:
> >>> Ah; the reason it's been working so far is that both lib/gis/gui.tcl
> >>> and gui/tcltk/gis.m/gm.tcl set them, e.g.:
> >>> if {[catch {set env(GISDBASE) [exec g.gisenv get=GISDBASE]} error]} {
> >>> Any other code which uses select.tcl will need to do likewise.
> >>> Use of env() is less than ideal (there's already enough confusion
> >>> between GRASS variables and environment variables), but using separate
> >>> variables would require changing a lot of "global" statements.
> >> Changing above line to
> >> if {[catch {set env(GISDBASE) [exec g.dirseps -g [exec g.gisenv
> >> get=GISDBASE]]} error]} {
> >> in lib/gis/gui.tcl seems to work for me. Can I commit ?
> >> Should I also change this in gui/tcltk/gis.m/gm.tcl ?
> > Have you tried "file normalize"? If that works, it's preferable to
> > spawning g.dirseps.
> Is "file normalize" a TclTk thing or a Windows thing?
Tcl. From the file(n) manpage:
file normalize name
Returns a unique normalized path representation for the file-
system object (file, directory, link, etc), whose string value
can be used as a unique identifier for it. A normalized path is
an absolute path which has all '../', './' removed. Also it is
one which is in the ``standard'' format for the native platform.
On MacOS, Unix, this means the segments leading up to the path
must be free of symbolic links/aliases (but the very last path
component may be a symbolic link), and on Windows it also means
we want the long form with that form's case-dependence (which
gives us a unique, case-dependent path). The one exception con-
cerning the last link in the path is necessary, because Tcl or
the user may wish to operate on the actual symbolic link itself
(for example 'file delete', 'file rename', 'file copy' are
defined to operate on symbolic links, not on the things that
they point to).
