[GRASS-dev] r.los scales badly
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Tue Nov 20 06:46:19 EST 2007
I've done some time measurements with r.los.
Basically I'm working on a DTM raster of Austria derived from SRTM data.
Thus, the region has a native res of 90m and has 2224 rows and 2228 columns.
If I'm doing a r.los after g.region -pa res=360 it takes 1.719 s to
complete the calculation (time taken through the time command). With
res=180, res=120, res=90 I get the following table:
res t (s)
360 1.72
180 17.96
120 123.68
90 688.37
It scales very badly. Is this expected? Are there better algorithms for
calculating LOS then that used in r.los?
Regards,
Peter
