[GRASS-dev] raster offset with cairo driver
Thu Nov 22 14:06:19 EST 2007
Hamish wrote:
> I'm trying out the new Cairo driver. To make things easier I just
> added support for it to d.out.file: use the -c flag with a raster
> image format.
> As AFAICT there is no user documentation, so I also added a small wiki
> page for it: http://grass.gdf-hannover.de/wiki/Cairo_driver
> It is missing a display/drivers/cairo/description.html page, modeled
> after the equivalent PNG driver page.
> There's a problem in that the raster data is being rendered offset vs.
> the vector data. For a window with the same aspect ratio as the region
> it seems to line up ok. Else, not.
The code overlooks the fact that the top-left coordinates are
subjected to the scaling.
I should have a fix shortly.
> There's another problem with fonts- True/FreeType fonts gets scrambled.
> This reminds me of a long ago bug in d.text.freetype, fixed in rev 1.42.
> "use correct pitch for reading bitmap buffer & fix scrambled letters"
>  http://freegis.org/cgi-bin/viewcvs.cgi/grass6/display/d.text.freetype/main.c
> example:  http://bambi.otago.ac.nz/hamish/grass/bugs/sf_cairo2.png
>  (d.* commands given on the above wiki page)
I was looking into this; it appears that I forgot about it.
