[GRASS-dev] G_is_double()
Sun Nov 25 14:04:42 EST 2007
Martin Landa wrote:
> I would like to add to the GIS library (strings.c) new fns
> G_is_double(char *str) and G_is_int(char *str). Any objections?
With what definition? E.g. does G_is_double() recognise numbers
without a point? Does it use the locale's decimal separator or always
a dot? Does G_is_int() recognise octal/hex? What about a leading "+"
sign?
Personally, I suggest leaving this to the modules. Otherwise,
whichever syntax you choose, code well tend to use the library
functions regardless of whether their syntax is appropriate for the
specific purpose.
