[GRASS-dev] 6.3.0 release - need to set default font
Hamish
hamish_nospam at yahoo.com
Sun Nov 25 17:42:09 EST 2007
> Michael Barton wrote:
> > What about making GRASS_FONT a GRASS variable rather than a shell variable?
> > I assume that it then could be set by g.gisenv (ending up in .grassrc6) and
> > consequently would then persist across working sessions.
Glynn Clements wrote:
> It should go into the user's environment, via ~/.grass.bashrc or one
> of the standard shell initialisation scripts, like any other user
> preference.
my guess here is that Michael is not seeing the GRASS_FONT set in .grass.bashrc
as he is working in a GIS.m lauched by init.sh *before* the grass terminal
session (and thus .grass.bashrc) is run. If gis.m is run from the grass
terminal prompt it should see it.
If that is the case a previously mooted solution is to have a ~/.grassrc file
which is sourced earlier in the game, before GUI subprocesses are spawned.
If we do add that, an idea of what a possible GRASS 7 ~/.grass/ dir might
contain could help reduce migration issues later.
Hamish
____________________________________________________________________________________
Be a better sports nut! Let your teams follow you
with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
