[GRASS-dev] 6.3.0 release - need to set default font
Sun Nov 25 21:33:28 EST 2007
Michael Barton wrote:
> In any case, the user still has to manually edit this file, which is
> difficult in a non-Linux environment.
if you can find a command prompt on mac/linux and you use Bash:
  echo "export GRASS_FONT=Vera" >> ~/.grass.bashrc
I'm not sure what the windows version would look like, something like:
  echo "set GRASS_FONT=Vera" >> %HOME%\.grass.dosrc
(then .grass.dosrc would need to be sourced by init.bat)
Hamish
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
