[GRASS-dev] Re: WinGrass testing results 6.3.0rc2
Moritz Lennert mlennert at club.worldonline.be
Tue Nov 27 15:45:59 EST 2007
Michael Barton wrote:
> This helps a LOT. I think it also explains why NVIZ doesn't work (although I
> don't understand why it DOES work on some systems). NVIZ is launched from a
> script.  > IIRC, there at least some scripts get *.bat equivalents. Is/was this
> the case for the script named "nviz"?
Yes and no. The *.bat equivalents of the shell scripts are acutally just
a call to the GRASS_SH to launch the shell script, where GRASS_SH will
be msys' sh.exe for those who installed it and configured the
grass63.bat file.
Nviz' case is different as the nviz.bat file directly calls
%GISBASE%\etc\nviz2.2\nviz.exe and so doesn't need a shell. So, you do
not need to have msys installed to launch nviz.
> Everyone here has installed mysys as
> suggested in the README. But it is nice to know that it is NOT needed. The
> problem then is that you can't run any of the scripts and some of these are
> important.
Obviously they are, although most are "just" a combination of different
grass commands with some awk/sed/etc magic thrown in as a bonus. So many
of the scripts can be reproduced by hand if really needed.
The idea for the future is to replace all the shell scripts with
equivalents in a more portable language such as python. As python will
be an obligatory dependency for anyone who wants to use the gui, it
sounds like the best choice for replacement.
> If I understand you correctly, if we modify the grass63.bat to make sure
> that it correctly indicates the location of mysys (we are just installing it
> in the default location), scripts (including nviz) *should* run.
As mentioned above, nviz should run in any case. If it doesn't then
there is a problem and we need to identify it.
I'll try to find time tomorrow to squat a colleague's computer which has
nothing (neither grass not tcltk) installed, yet, in order to test some
more.
Benjamin also had problems with nviz
(http://grass.itc.it/pipermail/grass5/2007-October/033804.html), but
this was in what I would call a "non-standard" environment as he tried
to work from within msys.
> Another question for the general group here. I'm about to try to convince a
> classroom lab manager to put this on the computers in the lab. Is there any
> problem to installing mysys in a tightly managed lab environment? Are we
> likely to run into any permission problems trying to run GRASS in such an
> environment (i.e., where students do not have write permission outside their
> own home directories)?
No idea.
Moritz
