[GRASS-dev] [grass-doc I][549] Just a typo in http://grass.itc.it/grass63/manuals/html63_user/rasterintro.html
grass-dev at lists.osgeo.org grass-dev at lists.osgeo.org
Fri Nov 30 13:13:58 EST 2007
doc I item #549, was opened at 2007-11-30 18:13
Status: Open
Priority: 3
Submitted By: Nikos Alexandris (nikosa)
Assigned to: Nobody (None)
Summary: Just a typo in http://grass.itc.it/grass63/manuals/html63_user/rasterintro.html
Issue status: None
Doc section: raster
GRASS version: None
Doc timestamp (YYMMDD):
Initial Comment:
A minor issue...
In: http://grass.itc.it/grass63/manuals/html63_user/rasterintro.html
in: There are a few exceptions to this: r.in.* programs read the data cell-for-cell, with no resampling. When reading non-georeferenced data, the imported map will usually have its lower-left corner at (0,0) in the location's coordinate system;   "ther"   user needs to use r.region to "place" the imported map.
It should be "the".
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=207&aid=549&group_id=21
