[GRASS-dev] ganim troubles in latest cvs
Glynn Clements
glynn at gclements.plus.com
Mon Oct 1 12:15:49 EDT 2007
Kirk Wythers wrote:
> On Sep 30, 2007, at 11:23 PM, Michael Barton wrote:
> > Well, after asking for help, I figured out how to this without the
> > dread
> > regexp ;-). This might even be a bit better routine.
> > Anyway, I can't commit this because I'm out of town, but if anyone
> > wants to
> > try it, you need to change lines in procedure GmAnim::main (module
> > animate.tcl). Replace the commented lines with the uncommented
> > lines below.
> > foreach line $reglist {
> > set line [string trim $line]
> > set key [lindex [split $line "="] 0]
> > switch $key {
> > nsres {set oldres1 [lindex [split $line "="] 1]}
> > ewres {set oldres2 [lindex [split $line "="] 1]}
> > rows {set vrows [lindex [split $line "="] 1]}
> > cols {set vcols [lindex [split $line "="] 1]}
> > # regexp {nsres= *([0-9]+)} $region dummy oldres1
> > # regexp {ewres= *([0-9]+)} $region dummy oldres2
> > # regexp {rows= *([0-9]+)} $region dummy vrows
> > # regexp {cols= *([0-9]+)} $region dummy vcols
> Michael,
> Thanks for the email. I made the following changes but ended up with
> a new error.
Add:
set reglist [split $region "\n"]
