[GRASS-dev] macosx compilation error in d.m
Glynn Clements
glynn at gclements.plus.com
Mon Oct 1 14:38:14 EDT 2007
Agustin Diez Castillo wrote:
> d.m.html not found, but no problem when make is done in
> /Users/Shared/grasssource/grass6/gui/tcltk/d.m
Can you please try the following:
1. Delete the files:
dist.i686-apple-darwin8.10.1/docs/html/d.m.html
dist.i686-apple-darwin8.10.1/scripts/d.m
gui/tcltk/d.m/d.m.tmp.html
2. Run "make -C gui/tcltk/d.m"
3. Report any errors, and whether any of the files mentioned in #1
above exist.
4. Repeat steps 2 and 3.
This problem only occurs on certain systems (possibly depending upon
the version of "make"). I can't reproduce it here. Also, it has only
been reported with regard to d.m and gis.m, although exactly the same
rules are used for other scripts.
