[GRASS-dev] ganim troubles in latest cvs
Kirk Wythers
kwythers at umn.edu
Tue Oct 2 08:04:00 EDT 2007
Just rebuilt with:
# regexp {nsres= *([0-9]+)} $region dummy oldres1
# regexp {ewres= *([0-9]+)} $region dummy oldres2
# regexp {rows= *([0-9]+)} $region dummy vrows
# regexp {cols= *([0-9]+)} $region dummy vcols
set reglist [split $region "\n"]
foreach line $reglist {
set line [string trim $line]
set key [lindex [split $line "="] 0]
switch $key {
nsres {set oldres1 [lindex [split $line "="] 1]}
ewres {set oldres2 [lindex [split $line "="] 1]}
rows {set vrows [lindex [split $line "="] 1]}
cols {set vcols [lindex [split $line "="] 1]}
Here is the new error (upon starting GmAnim):
invalid command name "Proc"
while executing
"Proc GmAnim::do_run {} {
# procedure that displays maps in an animation and controls the
animation
global loop
global swing
global a..."
(file "/Applications/GRASS-6.3.app/Contents/MacOS/etc/gm/
animate.tcl" line 635)
invoked from within
"source /Applications/GRASS-6.3.app/Contents/MacOS/etc/gm/animate.tcl"
(in namespace eval "::" script line 1)
invoked from within
"namespace eval :: $auto_index($name)"
(procedure "auto_load" line 13)
invoked from within
"auto_load $name [uplevel 1 {::namespace current}]"
(autoloading "GmAnim::main")
invoked from within
"GmAnim::main"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .mainframe.topf.tb1.bbox4.b0"
(command bound to event)
On Oct 1, 2007, at 9:17 PM, Michael Barton wrote:
> Kirk,
> You seem to be missing a line (maybe my fault). Note the line defining
> reglist.
> Michael
> switch $key {
> On 10/1/07 6:36 AM, "Kirk Wythers" <kwythers at umn.edu> wrote:
>> On Sep 30, 2007, at 11:23 PM, Michael Barton wrote:
>>> Well, after asking for help, I figured out how to this without the
>>> dread
>>> regexp ;-). This might even be a bit better routine.
>>> Anyway, I can't commit this because I'm out of town, but if anyone
>>> wants to
>>> try it, you need to change lines in procedure GmAnim::main (module
>>> animate.tcl). Replace the commented lines with the uncommented
>>> lines below.
>>> switch $key {
>> Michael,
>> Thanks for the email. I made the following changes but ended up with
>> a new error. I might have altered the wrong file. Here is what I
>> tried.
>> From the file ~/src_intel/grass-6.3.cvs/gui/tcltk/gis.m/animate.tcl
>> # set initial canvas geometry to match region
>> if {[catch {set region [exec g.region -ugp]} error]} {
>> Gm::errmsg $error
>> switch $key {
>> New error when startring up GmAnim.
>> can't read "reglist": no such variable
>> while executing
>> "foreach line $reglist {
>> switch $key {
>> nsres {..."
>> (procedure "GmAnim::main" line 28)
>> invoked from within
>> "GmAnim::main"
>> invoked from within
>> "uplevel \#0 $cmd"
>> invoked from within
>> Perhaps this is not what you intended?
>> Kirk
> __________________________________________
> Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
