[GRASS-dev] present state of GmAnim in gui
Kirk Wythers kwythers at umn.edu
Tue Oct 2 10:55:21 EDT 2007
Thanks to everyone who has responded to my GmAnim problem. Here is
the latest.
Suspecting that I had other issues in the src, I dumped the source,
re-downloaded new source from cvs, and ran update -dP.
Then I commented out the regex and added Michael's code:
    # set initial canvas geometry to match region
     if {[catch {set region [exec g.region -ugp]} error]} {
         Gm::errmsg $error
     #regexp {nsres= *([0-9]+)} $region dummy oldres1
     #regexp {ewres= *([0-9]+)} $region dummy oldres2
     #regexp {rows= *([0-9]+)} $region dummy vrows
     #regexp {cols= *([0-9]+)} $region dummy vcols
     set reglist [split $region "\n"]
     foreach line $reglist {
         set line [string trim $line]
         set key [lindex [split $line "="] 0]
         switch $key {
             nsres    {set oldres1 [lindex [split $line "="] 1]}
             ewres   {set oldres2 [lindex [split $line "="] 1]}
             rows    {set vrows [lindex [split $line "="] 1]}
             cols    {set vcols [lindex [split $line "="] 1]}
Presently GmAnim runs (using the same 30s raster from the worldclim
database). However I do notice that several of the buttons on the
animation window are broken, including the "exit" button, which gives
this error:
WARNING: <tmpanimregion541> nothing removed
     while executing
"exec g.remove region=$tmpregion --q"
     (procedure "GmAnim::cmd_exit" line 21)
     invoked from within
"GmAnim::cmd_exit"
     (command bound to event)
As an odd sidenote, the older version of GmAnim (before the animation
window was updated to have buttons on the top of the window) worked
fine with:
