[GRASS-dev] installed makefile cleanup
William Kyngesburye
woklist at kyngchaos.com
Tue Oct 2 15:52:57 EDT 2007
I sortof understand this. Until you can work out the necessary
changes (if you decide to), how about some minimal changes to the the
extension compilation working? Here are my revised changes to get it
working:
- platform.make.in:
RUN_GISBASE = ${ARCH_DISTDIR}
RUN_GISRC = ${RUN_GISBASE}/demolocation/.grassrc$
{GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}
this allows those to be overridden together in the make step, yet
still keeps the same configured default for a source build.
- grass.make.in: add after "ifdef INST_NOW":
ifdef INST_XTN
ARCH_INC = -I$(ARCH_DISTDIR)/include -I$(MODULE_TOPDIR)/include
ARCH_LIBPATH = -L$(ARCH_LIBDIR) -L$(MODULE_TOPDIR)/lib
endif
to look for includes and libs in both the module source/dist and the
installed GRASS
- grass.make.in: add at end:
ifdef INST_XTN
include $(MODULE_TOPDIR)/include/Make/Install_xtn.make
endif
and have a new Install_xtn.make fragment. This is just a trimmed
version of the main makefile with just install targets and any
unnecessary bits removed. It expects INST_DIR_XTN to be set in the
make command.
- module.make: for the bin/pgm and etc/pgm targets, conditionalize
the dependencies:
ifdef INST_XTN
$(BIN)/$(PGM)$(EXE): $(ARCH_CMD_OBJS)
else
$(BIN)/$(PGM)$(EXE): $(ARCH_CMD_OBJS) $(DEPENDENCIES)
endif
ifdef INST_XTN
$(ETC)/$(PGM)$(EXE): $(ARCH_CMD_OBJS)
else
$(ETC)/$(PGM)$(EXE): $(ARCH_CMD_OBJS) $(DEPENDENCIES)
endif
since the dependencies are based off ARCH_LIBDIR, which will be in
the extension source dir, they won't be found.
Then, to compile an extension, cd to its source and:
make INST_XTN=y GRASS_HOME=. MODULE_TOPDIR=/path/to/installed/grass
RUN_GISBASE=/path/to/installed/grass
Note: I still had problems with having an inst_xtn: target (similar
to the inst_now target) and putting INST_XTN=y before make. No
infinite loop now, but after completing the compilation
(successfully) it exits with an error:
/Applications/GRASS-6.3.app/Contents/MacOS/tools/mkhtml.sh
v.strahler ; mkdir -p ./dist.i686-apple-darwin8.10.1/docs/html ; /usr/
bin/install -c -m 644 v.strahler.tmp.html ./dist.i686-apple-
darwin8.10.1/docs/html/v.strahler.html ; for file in *.png *.jpg ;
do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /
usr/bin/install -c -m 644 $file ./dist.i686-apple-darwin8.10.1/docs/
html ; fi done 2> /dev/null ; true
INST_XTN= make
make[2]: *** No rule to make target `dist.i686-apple-darwin8.10.1/lib/
libgrass_display.dylib', needed by `dist.i686-apple-darwin8.10.1/bin/
v.strahler'. Stop.
make[1]: *** [inst_xtn] Error 2
make: *** [first] Error 2
rm v.strahler.tmp.html
It looks like, when done, INST_XTN gets set to something other than
"Y" and it tries to do a normal compile (thus trying to compile
dependencies).
Is there a particular reason for doing it this way, instead of having
no extra make target and putting INST_XTN after make?
To install the extension in a user-specified location:
RUN_GISBASE=/path/to/installed/grass INST_DIR_XTN=/path/to/user/xtn/
dir install
On Sep 23, 2007, at 8:17 PM, Glynn Clements wrote:
> As for the rest of it, we're probably better off starting from basics.
> The following might all be independently variable (with example
> locations):
> 1. Where to find the GRASS source tree (/usr/local/src/grass)
> 2. Where to find the extension code which is being compiled (/usr/
> local/src/mygrassext)
> 3. Where to find output files (/usr/local/src/grass/<module path>/
> OBJ.<arch>)
> 4. Where to find "part-installed" files (/usr/local/src/grass/
> dist.<arch>)
> 5. Where to find the installed version of GRASS (/usr/local/grass6.3)
> 6. Where to put output files (/usr/local/src/grass/<module path>/
> OBJ.<arch>)
> 7. Where to put "part-installed" files (/usr/local/src/grass/
> dist.<arch>)
> 8. Where to install everything (/usr/local/grass6.3)
> 9. Where to find the Makefile fragments.
> AFAICT, there are three main cases:
> A. Compiling GRASS from scratch.
> B. Compiling additional modules on a system where a compiled GRASS
> is already installed.
> C. Compiling extensions on a system where a compiled GRASS is
> already installed.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
