[GRASS-dev] native WinGRASS and attribute data deadlock, next try
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Thu Oct 4 14:43:50 EDT 2007
I'd love to give this a spin on a Win2000 and XP box.
Unfortunately, I don't have acccess to one right now.
Moritz, could you email all the files you changed?
I will try to get hold of a Windows machine to compile
and test as soon as possible.
Benjamin
Moritz Lennert wrote:
>>>> My next suggestion is to re-write xdr_stdio to use read() and write()
>>>> instead of fread() and fwrite(), e.g.:
>>>> -    if (fread((caddr_t)lp, sizeof(long), 1, (FILE
>>>> *)xdrs->x_private) != 1)
>>>> +    if (read(fileno((FILE *)xdrs->x_private), (caddr_t)lp,
>>>> sizeof(long)) !=
>>>> sizeof(long))
>>> That seems to work !
>> Now that's strange. I was expecting it to provide more information on
>> the errors, not to work.
>> On Unix, read/write can return short counts on pipes. If a process
>> tries to write 4 bytes to a pipe, and there's only enough space for 2
>> bytes, write() will return 2 rather than waiting for the pipe to
>> drain. Similarly if you try to read more data than is available in the
>> pipe.
>> If you want to block until the requested amount of data has been read
>> or written, you need to either use readn/writen (which are
>> non-standard), or implement them yourself, e.g.:
>> ssize_t readn(int fd, void *buf, size_t count)
>>     ssize_t total = 0;
>>     while (total < count)
>>         ssize_t n = read(fd, (char *) buf + total, count - total)
>>         if (n < 0)
>>             return n;
>>         if (n == 0)
>>             break;
>>         total += n;
>>     return total;
>> ssize_t writen(int fd, const void *buf, size_t count)
>>     ssize_t total = 0;
>>         ssize_t n = write(fd, (const char *) buf + total, count - total)
>>         if (n < 0)
>>             return n;
>>         if (n == 0)
>>             break;
>>         total += n;
>>     return total;
>> The above assumes that non-blocking I/O hasn't been enabled for the
>> descriptor. If it has, you need to either disable it for the duration
>> of the function or use select() or poll() to wait until the descriptor
>> is ready.
>>> I'll post new binaries as soon as compilation is over, so that others
>>> can
>>> test as well.
>> If you want to test it, I'd suggest reducing the size of the pipes in
>> lib/db/dbmi_client/start.c. A larger pipe won't prevent errors, but it
>> may make them less likely to show up.
> I changes the values in lines 146 & 147 and went down all the way to 2 (
> from the current setting of 250000): I cannot reproduce the
> deadlock...v.out.ogr works as it should.
> So, where should we go from here ? Is it still wiser to implement
> readn/writen as you suggest above ? If yes, where and how do I see if
> non-blocking I/O is enabled or not (on MSDN it says: "In multithreaded
> programs, no locking is performed. The file descriptors returned are
> newly opened and should not be referenced by any thread until after the
> _pipe call is complete." - Is this what you mean ?) ?
> Benjamin, could you try the simple write/read (instead of fwrite/fread)
> solution, so that we can make sure that this works for someone else ?
> Moritz
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
