[GRASS-dev] Re: [GRASS-CVS] hamish: grass6/lib/init init.sh, 1.119, 1.120
Moritz Lennert mlennert at club.worldonline.be
Sat Oct 6 16:32:06 EDT 2007
On Sat, October 6, 2007 09:53, Markus Neteler wrote:
> On Sat, Oct 06, 2007 at 07:05:00AM +0200, grass at intevation.de wrote:
>> Author: hamish
>> Update of /grassrepository/grass6/lib/init
>> In directory doto:/tmp/cvs-serv6411
>> Modified Files:
>>         init.sh
>> Log Message:
>> add test so don't overwrite VAR file without testing. I just commented
>> the whole
>> thing out though after fixing it, as the VAR and $MAPSET/dbf/ should be
>> created on demand. To a raster-only or postgres-only user they are just
>> file pollution.  code bug #502
>> Index: init.sh
>> RCS file: /grassrepository/grass6/lib/init/init.sh,v
>> retrieving revision 1.119
>> retrieving revision 1.120
>> diff -u -d -r1.119 -r1.120
>> --- init.sh     3 Oct 2007 08:30:48 -0000       1.119
>> +++ init.sh     6 Oct 2007 05:04:58 -0000       1.120
>> @@ -495,9 +495,10 @@
>>                         cp "$GISDBASE/$LOCATION_NAME/PERMANENT/WIND"
>> "$LOCATION/WIND"
>>                         echo "Missing WIND file fixed"
>>                         # predefine DBF driver
>> -                       echo "DB_DRIVER: dbf" > "$LOCATION/VAR"
>> -                       echo "DB_DATABASE:
>> \$GISDBASE/\$LOCATION_NAME/\$MAPSET/dbf/" >> "$LOCATION/VAR"
>> -                       mkdir "$LOCATION"/dbf
>> +                       #  why is this needed ??
>> +                       #echo "DB_DRIVER: dbf" > "$LOCATION/VAR"
>> +                       #echo "DB_DATABASE:
>> +                       #mkdir "$LOCATION"/dbf
> This is needed, if you start GRASS from CMD line with
> full path to a non-existing mapset (which is then created).
Why is the dbf path creation needed ? You might never want to use dbf on
this new mapset...
I guess the automatic dbf path creation should be part of db.connect...
> Above was there for many months without problems. The recent
> problem seems to arise from a different modification.
Yes, the revision just before
(http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/init/init.sh.diff?r1=1.118&r2=1.119):
RCS file: /home/grass/grassrepository/grass6/lib/init/init.sh,v
retrieving revision 1.118
diff -u -r1.118 -r1.119
--- grass6/lib/init/init.sh	2007/09/20 14:18:01	1.118
+++ grass6/lib/init/init.sh	2007/10/03 08:30:48	1.119
@@ -1,7 +1,7 @@
 #!/bin/sh
-# $Id: init.sh,v 1.118 2007/09/20 14:18:01 moritz Exp $
+# $Id: init.sh,v 1.119 2007/10/03 08:30:48 markus Exp $
 # MODULE:   	GRASS Initialization
 # AUTHOR(S):	Original author unknown - probably CERL
@@ -685,6 +685,11 @@
 	echo "Building user fontcap ..."
 	g.mkfontcap
 fi
+# predefine DBF driver if DB connection not defined
+echo "DB_DRIVER: dbf" > "$LOCATION/VAR"
+echo "DB_DATABASE: \$GISDBASE/\$LOCATION_NAME/\$MAPSET/dbf/" >>
"$LOCATION/VAR"
+mkdir "$LOCATION"/dbf
 trap "" 2 3 15
Moritz
