[GRASS-dev] native WinGRASS and attribute data deadlock, next try
Moritz Lennert
mlennert at club.worldonline.be
Mon Oct 8 15:27:34 EDT 2007
>> My preferred approach would be to change lib/db/dbmi_base to simply
>> not use XDR (that isn't anywhere near as much work as it might sound).
> I have attached a patch to do this. I haven't committed it yet in case
> it breaks anything (and if it breaks anything, it may break a lot of
> things).
> Could someone familiar with DBMI and vectors test it out?
> Index: lib/db/dbmi_base/xdr.c
> RCS file: /grassrepository/grass6/lib/db/dbmi_base/xdr.c,v
> retrieving revision 1.5
> diff -u -r1.5 xdr.c
> --- lib/db/dbmi_base/xdr.c 26 Apr 2007 16:44:44 -0000 1.5
> +++ lib/db/dbmi_base/xdr.c 7 Oct 2007 20:50:35 -0000
> @@ -15,47 +15,84 @@
> #include "xdr.h"
> +#ifdef __MINGW32__
> +#define USE_STDIO 0
> +#define USE_READN 1
> +#else
> +#define USE_STDIO 1
> +#define USE_READN 0
> +#endif
> +#ifndef USE_STDIO
> +#include <unistd.h>
> +#endif
> static FILE *_send, *_recv;
> -void
> -db__set_protocol_fds (FILE *send, FILE *recv)
> - _send = send;
> - _recv = recv;
> +#if USE_READN
> -int
> -xdr_begin_send(XDR *xdrs)
> +static ssize_t readn(int fd, void *buf, size_t count)
> - xdrstdio_create (xdrs, _send, XDR_ENCODE);
> + ssize_t total = 0;
> + while (total < count)
> + ssize_t n = read(fd, (char *) buf + total, count - total)
the MINGW compiler complains about a missing ';' at the end here. gcc
under linux doesn't...don't know why.
> + ssize_t n = write(fd, (const char *) buf + total, count - total)
same here
Moritz
