[GRASS-dev] native WinGRASS and attribute data deadlock, next try
Moritz Lennert mlennert at club.worldonline.be
Mon Oct 8 16:46:38 EDT 2007
>> My preferred approach would be to change lib/db/dbmi_base to simply
>> not use XDR (that isn't anywhere near as much work as it might sound).
> I have attached a patch to do this. I haven't committed it yet in case
> it breaks anything (and if it breaks anything, it may break a lot of
> things).
> Could someone familiar with DBMI and vectors test it out?
Rapid testing in Debian (v.out/in.ogr, v.univar, d.vect.thematic, g.copy)
with dbf, sqlite, postgres does not show any problems. Will test in
windows as soon as I solve the compile problems.
Moritz
