[GRASS-dev] [grass-code R][506] v.what.rast should be able to
use other methods like bilinear
Markus Neteler
neteler at itc.it
Mon Oct 8 19:00:35 EDT 2007
William A. Perkins wrote:
> Maciej> BTW - anybody knows how to just copy a column from table to
> Maciej> table? Or update an existing column in one column with the
> Maciej> content of a column in another table? That's be the easiest
> Maciej> workaround.
> What I usually end up doing is temporarily connecting to a Postgres
> database, for which this statement works (in your example):
Not sure but v.db.join comes to mind... it includes even a trick
to make joins in SQLite (which isn't really supported by it).
Markus
View this message in context: http://www.nabble.com/-grass-code-R--506--v.what.rast-should-be-able-to-use-other-methods-like-bilinear-tf4589359.html#a13106492
Sent from the Grass - Dev mailing list archive at Nabble.com.
