[GRASS-dev] db.execute: ".execute" suffix missing in man page
Glynn Clements
glynn at gclements.plus.com
Tue Oct 9 19:47:53 EDT 2007
Maciej Sieczka wrote:
> In Firefox and Lynx browsers the ".execute" part of
> "db.execute" is missing above the module description. It
> also not there in "man db.execute" output.
G_basename
> Does anybody confirm?
Confirm:
$ db.execute --help
Usage:
db [-i] [input=name] [driver=name] [database=name] [--verbose]
[--quiet]
G_parser() does:
G_basename(tmp_name, "exe");
G_basename() is described thus:
* \fn char * G_basename (char *filename, const char *desired_ext)
* \brief Truncates filename to the base part (before the last '.')
* if it matches the extension, otherwise leaves it unchanged.
But it actually only checks if the specified extension is a prefix of
the actual extension rather than a complete match.
Suggested fix (untested):
char * G_basename(char *filename, const char *desired_ext)
/* Find the last . in the filename */
char *dot = strrchr(filename, '.');
if (dot && G_strcasecmp(dot + 1, desired_ext) == 0)
*dot = '\0';
return filename;
