[GRASS-dev] [grass-code I][507] r.in.xyz: a segfault with particular dataset
Wed Oct 10 02:59:23 EDT 2007
> > code I item #507, was opened at 2007-10-09 17:11
> > Submitted By: Maciej Sieczka (msieczka)
> > Summary: r.in.xyz: a segfault with particular dataset
> > Issue type: module bug
> > Initial Comment:
> > r.in.xyz has been segfaulting with a particular dataset. It's quite
> > big (23 MB bzipped) and I don't know how to provide it but let me
> > know if ther's a need+way to.
> > Details:
> > $r.in.xyz -g input=tin_nieciag.xyz output=tin_nie ciag.xyz method=min
> > type=DCELL fs="|" x=1 y=2 z=3 percent=100
> > n=5725102.149034 s=5705608.286234 e=587119.577053 w=568715.830892
> > b=69.431216 t= 224.696106
> > $ g.region n=5725102.149034 s=5705608.286234 e=587 119.577053
> > w=568715.830892 res=1 -a
Glynn responded:
> If res == 1, then:
> cols = 587119.577053 - 568715.830892 = 18403.74616099999 = 18404
> rows = 5725102.149034 - 5705608.286234 = 19493.86280000024 = 19494
> At 8 bytes per cell, the total size of the map is:
>  18404 * 19494 * 8 = 2870140608 bytes
> This is larger than 2GiB, causing the arithmetic (which uses "int") to
> overflow.
> > $ gdb r.in.xyz
> > $ run input=tin_nieciag.xyz output=tin_nie ciag.xyz method=min
> > Starting program: /usr/local/grass-6.3.cvs/bin/r.in.xyz
> > input=tin_nieciag.xyz output=tin_nieciag.xyz method=min type=DCELL
> > fs="|" x=1 y=2 z=3 percent=100 Scanning data ... 67%
> > Program received signal SIGSEGV, Segmentation fault.
> > 0x00002aaaaabf3c09 in G_is_d_null_value (dcellVal=0x2aaa2cd4e960) at
> > null_val.c:502 502             if(((unsigned char *) dcellVal)[i] !=
> > (gdb) bt
> > #2  0x000000000040439c in update_min (array=0x2aaaab3b4010,
> > #cols=18405, row=14767, col=4767, map_type=2,
> > #value=155.11966910999999) at support.c:74
> int update_min(void *array, int cols, int row, int col, RASTER_MAP_TYPE
> map_type, double value) {
>     void *ptr;
>     DCELL old_val;
>     ptr = array;
>     ptr = G_incr_void_ptr(ptr, ((row*cols)+col)*G_raster_size
> (map_type));
>     if( G_is_null_value(ptr, map_type) )
> There are two problems here:
> 1. row, col, and cols are all "int"s (typically 32-bit signed
> integers), so (row*cols)+col is performed at that width, which will
> overflow at 2GiB.
> 2. G_incr_void_ptr() takes the increment as an "int", which is limited
> to 2GiB.
> For this to work, we need to use a 64-bit type on 64-bit systems. We
> also need to use an unsigned type, as a 32-bit system can allocate
> memory up to 4GiB, not 2GiB (unlike off_t, size_t is unsigned).
> Which types are 64-bit on 64-bit Linux systems? ptrdiff_t has to be;
> size_t probably will be.
> [I was going to point out that malloc() is limited to a size_t, so the
> array couldn't be larger than that, but the array is allocated with
> calloc(), which could theoretically produce a >4GiB array with only a
> 32-bit size_t.]
> I suggest:
> 1. Changing G_incr_void_ptr() to use size_t.
> 2. Changing G_raster_size() to return size_t (that's what sizeof
> returns, which is the reason for size_t's existence).
> 3. Casting "cols" to a size_t, so that the index calculation is
> performed at size_t width.
> If size_t isn't enough to index the array (i.e. you have a 32-bit
> size_t on a platform which can calloc() more than 4GiB), you lose
> regardless.
- This is a problem with the size of the region settings, not the size
of the input file. Thus the workaround is to use the percent=25 option
to allocate less memory and do the import with multiple scans of the
data, or readjust the resolution with 'g.region res=2 -a' or so.
- If it had been a problem with the file, redirecting from stdin
instead of explicitly giving the file name might have helped. (but then
percent is locked at 100% :-/). Others have reported success with input
files >4GB.
- the program does try and test to see if there is enough memory
to proceed before it does any processing. (main.c line 277) But that
won't help SegFaults due to trying to write to a broken memory address.
- I don't know enough about 64bit and LFS issues to fix this myself
without introducing all sorts of errors so must leave it to someone else.
Hamish
