[GRASS-dev] [grass-code R][510] v.to.db option=length: please
report line's 3d length
Hamish
hamish_nospam at yahoo.com
Sat Oct 13 07:02:51 EDT 2007
> Maciej:
> > Same request applies to v.distance. It apparently assumes
> > input points are flat too. Consider 2 3d points:
Martin wrote:
> v.distance should be fixed in CVS (not tested with 3d lines...)
d.what.vect will give you a 3D distance to compare against for an easy test.
Hamish
____________________________________________________________________________________
Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase.
http://farechase.yahoo.com/
