[GRASS-dev] Re: g.region bugs [was: GRASS 6.3.0 release preparation]
Martin Landa
landa.martin at gmail.com
Mon Oct 15 09:47:31 EDT 2007
hm, I disabled G_aling_window(), seems to work... (in CVS)
Martin
2007/10/15, Maciej Sieczka <tutey at o2.pl>:
> Martin Landa wrote:
> > Maciej Sieczka wrote:
> >> Also, the bug g.region [2] is very serious. Any chances
> >> these 2 bugs could be fixed before relasing 6.3? It would be
> >> much better not to release with *known* bugs which might
> >> corrupt users data.
> >> [2]http://wald.intevation.org/tracker/?func=detail&atid=204&aid=489&group_id=21
> > should be fixed in CVS...
> Martin
> Yes it is! Cool.
> Yet, there is some more evil lurking in g.region - when the
> initial resolution is different than resolution requested in
> a "g.region vect=line res=1 -a" call, the region is set
> wrong (present in both CVS GRASS 6.2 and 6.3). Eg.:
> 1. Set the region to something like:
> $ g.region n=5680980 s=5680960 w=602440 e=602480 res=20 -g
> n=5680980
> s=5680960
> w=602440
> e=602480
> nsres=20
> ewres=20
> rows=1
> cols=2
> 2. Create a vector line within the region:
> $ echo "L 2 1
> 602473.66691719 5680962.45268225
> 602448.70284465 5680961.09147704
> 1 1" | v.in.ascii -n form=standard out=line
> 3. Set the region to match the extent of vector line and
> force resolution "1":
> $ g.region vect=line res=1 -ag
> n=5680980
> s=5680960
> w=602440
> e=602480
> nsres=1
> ewres=1
> rows=20
> cols=40
> The above g.region result is wrong. It should be:
> n=5680963
> s=5680961
> w=602448
> e=602474
> nsres=1
> ewres=1
> rows=2
> cols=26
> This happens when the initial region (set in point #1) is
> different than target resolution (requested in #3).
> Would you mind looking into this bug too?
> Best,
> Maciek
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
