[GRASS-dev] Re: g.region bugs [was: GRASS 6.3.0 release
preparation]
Glynn Clements
glynn at gclements.plus.com
Tue Oct 16 07:50:51 EDT 2007
Maciej Sieczka wrote:
> >> hm, I disabled G_aling_window(), seems to work... (in CVS)
> > Reverted in CVS.
> > If the user specifies -a, the region should be aligned.
> After Glynn reverted Martin's commit, I experience the
> following:
> $ g.region n=5680980 s=5680960 w=602440 e=602480 res=20 -ag
> n=5680980
> s=5680960
> w=602440
> e=602480
> nsres=20
> ewres=20
> rows=1
> cols=2
> cells=2
> $ echo "L 2 571600 5722275
> 571610 5722275" | v.in.ascii -n out=line form=standard --o
> $ g.region vect=line res=1 -ag
> ERROR: Invalid region: North must be larger than South
This is due to this change:
Index: lib/gis/align_window.c
RCS file: /grassrepository/grass6/lib/gis/align_window.c,v
retrieving revision 2.5
retrieving revision 2.6
diff -u -r2.5 -r2.6
--- lib/gis/align_window.c 13 Apr 2007 22:42:58 -0000 2.5
+++ lib/gis/align_window.c 15 Oct 2007 11:12:03 -0000 2.6
@@ -49,9 +49,9 @@
preserve = window->proj == PROJECTION_LL && window->east == (window->west+360);
window->south =
- G_row_to_northing (ceil(G_northing_to_row (window->south, ref)), ref);
+ G_row_to_northing (floor(G_northing_to_row (window->south, ref)), ref);
window->north =
- G_row_to_northing (floor(G_northing_to_row (window->north, ref)), ref);
+ G_row_to_northing (ceil(G_northing_to_row (window->north, ref)), ref);
window->east =
G_col_to_easting (ceil(G_easting_to_col (window->east, ref)), ref);
window->west =
Originally, it rounded both edges outwards (i.e. north up, south
down). The change makes it round inwards, so if it's less than a cell
high, the north and south edges will be the wrong way around.
Reverted in CVS.
