[GRASS-dev] r.in.gdal and "group"
Kirk Wythers kwythers at gmail.com
Tue Oct 16 10:03:31 EDT 2007
I must have missed the change in r.in.gdal where the required paramter
"output" was droped and replaced with "group".
I must not "get it"... because I don't understand what group a file
would be in before it is imported.
For example, I am importing a set a worldclim files with r.in.gdal. I
used to simply set the file to import with the input parameter, and
specify it's name with the output parameter.
Thanks,
Kirk
