[GRASS-dev] r.in.gdal and "group"
Glynn Clements
glynn at gclements.plus.com
Tue Oct 16 15:35:34 EDT 2007
Kirk Wythers wrote:
> > Only, which each change in lib/gis/parser.c, a full recompilation
> > after "make distclean" is needed to avoid shifted parameters
> > as you have seen.
> > Hope this clarifies it.
> > Markus
> Yes that does make sense. Thanks for the explanation. I did not
> realize that shifted paramteres carried over onto the html pages as
> well.
The top part of each HTML file (everything prior to the DESCRIPTION
section) is generated by running the program with the
--html-description flag. Thus, the HTML will always accurately reflect
the program, including any "mistakes" arising from a mismatch between
the module and libgis.
