[GRASS-dev] GRASS 6.2.2: gis.m crashes when there are more
than one map with same name in path
Glynn Clements
glynn at gclements.plus.com
Tue Oct 16 15:52:22 EDT 2007
Michael Barton wrote:
> This bug is a combination of TclTk and non-TclTk issues. The proximate
> 'cause' is that TclTk treats all data sent to stderr as real errors.
> The current fix in 6.3 involves select.tcl (which now adds @[mapset] to all
> selected items
Failure to add the @mapset probably results in a bug in the handling
of the case where the current mapset isn't the first one in the mapset
search path (an unqualified map name refers to the first map found
with that name, not necessarily the one in the current mapset).
