[GRASS-dev] GRASS 6.3.0 release preparation
Brad Douglas
rez at touchofmadness.com
Tue Oct 16 19:19:10 EDT 2007
On Tue, 2007-10-16 at 10:12 +0300, Maris Nartiss wrote:
> 3) Parallel make (-j 4) still fails. First failure:
> gcc -shared -o /home/ddd/soft/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gmath.6.3.cvs.so
> -L/home/ddd/soft/grass6/dist.i686-pc-linux-gnu/lib
> -Wl,--export-dynamic
> -Wl,-rpath-link,/home/ddd/soft/grass6/dist.i686-pc-linux-gnu/lib
> OBJ.i686-pc-linux-gnu/brent.o OBJ.i686-pc-linux-gnu/dalloc.o
> OBJ.i686-pc-linux-gnu/del2g.o OBJ.i686-pc-linux-gnu/eigen.o
> OBJ.i686-pc-linux-gnu/eigen_tools.o OBJ.i686-pc-linux-gnu/fft.o
> OBJ.i686-pc-linux-gnu/findzc.o OBJ.i686-pc-linux-gnu/gauss.o
> OBJ.i686-pc-linux-gnu/getg.o OBJ.i686-pc-linux-gnu/ialloc.o
> OBJ.i686-pc-linux-gnu/jacobi.o OBJ.i686-pc-linux-gnu/la.o
> OBJ.i686-pc-linux-gnu/lu.o OBJ.i686-pc-linux-gnu/max_pow2.o
> OBJ.i686-pc-linux-gnu/mult.o OBJ.i686-pc-linux-gnu/rand1.o
> OBJ.i686-pc-linux-gnu/svd.o -lgrass_gis -lgrass_datetime -lz
> -lfftw3 -lm && \
> (cd /home/ddd/soft/grass6/dist.i686-pc-linux-gnu/lib; ln -f -s
> /home/ddd/soft/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gmath.so)
> /usr/lib/gcc/i686-pc-linux-gnu/4.2.1/../../../../i686-pc-linux-gnu/bin/ld:
> cannot find -lgrass_gis
> collect2: ld returned 1 exit status
> make[2]: *** [/home/ddd/soft/grass6/dist.i686-pc-linux-gnu/lib/libgrass_gmath.6.3.cvs.so]
> Error 1
> make[2]: Leaving directory `/home/ddd/soft/grass6/lib/gmath'
You cannot build the libraries in parallel. It's bombing because
lib/gis hasn't finished (or started) compiling, yet. Virtually
everything depends on lib/gis.
73, de Brad KB8UYR/6 <rez touchofmadness com>
