[GRASS-dev] i18N guisection bug
Hamish
hamish_nospam at yahoo.com
Wed Oct 17 23:06:06 EDT 2007
Markus:
> > and the source code:
> > flag.gprint = G_define_flag();
> > flag.gprint->key = 'g';
> > flag.gprint->description = _("Print in shell script style");
> > flag.gprint->guisection = _("Print;Shell Script");
> > Questions:
> > - is it correct to apply _() gettext macros to >guisection?
Glynn:
> I don't think so. If it's being used for Tk window names, it shouldn't
> be localised. If it's also being used for tab titles, the titles
> should be localised within the GUI code with G_msg.
The opt->guisection setting selects the tab into which the option/flag will belong in the module's auto-generated GUI. If the parser code which generates the 'g.module --tcltk' code included G_msg(), what use would that be to the translators? ie how would they compile a list of phrases to be translated without running every module and parsing the --tcltk output?
Hamish
