[GRASS-dev] make on SMP [was: GRASS 6.3.0 release preparation]
Soeren Gebbert soerengebbert at googlemail.com
Thu Oct 18 04:37:16 EDT 2007
Well, i think the easiest way to solve this gpde issue to move the N_pde.h
header file into grass6/include.
So there should be no need to copy it.
I have kept the header file in the source directory for the
doxygen documentation generation. To have all the used structures
documented.
But i guess i can tell doxygen to use ../../include/N_pde.h instead of
keeping the header
file in the source dir.
Soeren
2007/10/18, Glynn Clements <glynn at gclements.plus.com>:
> Maciej Sieczka wrote:
> > >>>> sorry but I'm not an make guru and thus see it simple: if I run
> comand
> > >>>> "make -j4" it should get along with it or fail with "err blah
> parallel
> > >>>> buld not supported". Current CVS version does neither of it.
> > >>> I hope we don't give up so early. Probably just a few Makefiles
> > >>> need to be fixed (basically, get the target order right therein).
> > >>>> As multicore CPU's are getting more popular, more and more users
> will be
> > >>>> trying to run "make -j X" and thus report failure as bug [1].
> > >>> Not always. As written yesterday, "make -j3" worked for me on my
> RHEL5
> > >>> box. Now testing with Mandriva.
> > >>>> If I can help with testing, drop me instructions. I have Gentoo
> ~x86
> > >>>> system (gcc version 4.2.1; GNU Make 3.81).
> > >>> Please help testing. Just run it and see if and where it fails.
> > >>> Then check the problematic Makefile(s) for correct order:
> > >>> http://grass.gdf-hannover.de/wiki/Development#GRASS_Makefile_writing
> > >> As for testing: I get the following errors with make -j3 on
> > >> Intel Core 2 6600 running 2.6.15-29-amd64-xeon (Ubuntu Dapper):
> > >> Errors in:
> > >> /home/maciek/src/straight/grass63/lib/gpde
> > >> /home/maciek/src/straight/grass63/imagery/i.vpoints
> > >> /home/maciek/src/straight/grass63/misc/m.cogo
> > >> /home/maciek/src/straight/grass63/raster/r.gwflow
> > >> /home/maciek/src/straight/grass63/raster/r.to.rast3elev
> > >> /home/maciek/src/straight/grass63/raster3d/r3.gwflow
> > >> /home/maciek/src/straight/grass63/vector/v.sample
> > > What errors, exactly?
> > That's all it says:
> > Started compilation: Thu Oct 18 00:07:37 CEST 2007
> > Errors in:
> > In case of errors please change into the directory with
> > error and run 'make'. If you get multiple errors, you need
> > to deal with them in the order they appear in the error log.
> > If you get an error building a library, you will also get
> > errors from anything which uses the library.
> > Finished compilation: Thu Oct 18 00:11:12 CEST 2007
> > make: *** [default] Error 1
> > If you'd like to see full make and configure output they are
> > here [1].
> The relevant make output is necessary.
> lib/gpde:
>         N_arrays.c:19:25: error: grass/N_pde.h: No such file or directory
> I've just figured out what's going on; it's the way that phony targets
> are being used. E.g. lib/gpde/Makefile has:
>         default: headers lib
>         headers:
>                 for file in ./N_*.h ; do $(INSTALL_DATA) $$file
> $(GISBASE)/include/grass/ ; done
>         lib: headers
> "headers" is a prerequisite of "lib", and so will be built before it.
> But "lib" is defined in Lib.make as:
>         lib: $(GRASS_LIBRARY_TYPE)
> $(GRASS_LIBRARY_TYPE) is either "shlib" or "stlib". Assuming "shlib",
> that's defined in Shlib.make as:
>         shlib: $(SHLIB)
> When there are multiple rules for a given target, all of the
> dependencies are merged, so in effect we have:
>         lib: headers $(SHLIB)
> IOW, the headers target and the actual shared library are built in
> parallel.
> Using phony targets for real files (as opposed to e.g. "clean") sucks.
> What we really want is a dependency like:
>         $(SHLIB): headers
> But it isn't clear how to abstract out the library type. Note that:
>         $(GRASS_LIBRARY_TYPE): headers
> won't work, as that just gives e.g.:
>         shlib: headers
>         shlib: $(SHLIB)
> which is equivalent to:
>         shlib: headers $(SHLIB)
> which will still result in headers and $(SHLIB) being built in
> parallel.
> Note to self (and anyone else who it concerns): a dependency such as
> "foo: bar" does *not* make "foo" into an alias for "bar". Sure, making
> foo will make bar, but if foo has other prerequisites, they will be
> made in parallel with bar, not before it.
> Ugh. I don't immediately know how to solve this, but I do at least
> know what's going on now. I'm fairly sure that that this is the cause
> of many of the outstanding problems with parallel builds.
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20071018/4f4ddc99/attachment.html
