[GRASS-dev] problems compiling GRASS 6.3 cvs on Mac
William Kyngesburye woklist at kyngchaos.com
Sat Oct 20 20:24:13 EDT 2007
Hehe, I just had the same minutes ago...  From the link command, I
see that the libtiff dir is not included:
gcc -L/Users/Shared/src/GRASS/cvs/grass6/dist.i686-apple-darwin8.10.1/
lib -arch ppc -arch i386 -arch ppc -arch i386  -L/usr/local/pgsql/
lib   -o /Users/Shared/src/GRASS/cvs/grass6/dist.i686-apple-
darwin8.10.1/bin/r.out.tiff OBJ.i686-apple-darwin8.10.1/r.out.tiff.o
-lgrass_gis -lgrass_datetime -lz     -ltiff   -lz
I think the recent makefile cleanup may have triggered a problem with
the r.out.tiff makefile.  It seems that EXTRA_CFLAGS is no longer
added to link commands (which makes sense).  But the r.out.tiff
makefile doesn't add the libtiff path to LIBES:
LIBES = $(GISLIB) $(TIFFLIB)
It should probably be (indeed, this fixes it for me):
LIBES = $(GISLIB) $(TIFFLIBPATH) $(TIFFLIB)
(And TIFFLIBPATH should be removed from EXTRA_CFLAGS)
On Oct 20, 2007, at 7:00 PM, Michael Barton wrote:
> William,
> I just tried to update and compile GRASS 6.3 on my Mactel MacBook.
> (I did a make distclean first)
> I had the usual d.m error, but also can't compile r.out.tiff.
> Here is the error:
> cmb-MBP-2:~/grass_dev/grass6/raster/r.out.tiff cmbarton$ make
> gcc -L/Users/cmbarton/grass_dev/grass6/dist.i686-apple-darwin8.10.3/
> lib      -o /Users/cmbarton/grass_dev/grass6/dist.i686-apple-
> darwin8.10.3/bin/r.out.tiff OBJ.i686-apple-darwin8.10.3/
> r.out.tiff.o  -lgrass_gis -lgrass_datetime -lz     -ltiff   -lz
> /usr/bin/ld: can't locate file for: -ltiff
> collect2: ld returned 1 exit status
> make: *** [/Users/cmbarton/grass_dev/grass6/dist.i686-apple-
> darwin8.10.3/bin/r.out.tiff] Error 1
> I had no problem with configure. I'm downloading a new all
> frameworks to see if I'm missing anything new and then will compile
> again. (Any chance you could put a date on these in your site so it
> would be clear which, if any have been updated recently?)
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
