[GRASS-dev] [grass-code I][518] Problem compiling with ffmpeg 6.2.3RC1
grass-dev at grass.itc.it grass-dev at grass.itc.it
Sun Oct 21 15:05:16 EDT 2007
code I item #518, was opened at 2007-10-21 22:05
Status: Open
Priority: 3
Submitted By: Māris Nartišs (marisn)
Assigned to: Nobody (None)
Summary: Problem compiling with ffmpeg 6.2.3RC1
Issue type: None
Issue status: None
GRASS version: 6.2.2
GRASS component: build
Operating system: Linux
Operating system version:
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
gcc version 4.2.1
ffmpeg-0.4.9_p20070616-r1
gcc -I/home/ddd/soft/grass-6.2.3RC1/dist.i686-pc-linux-gnu/include  -g -O2    -fPIC    -DPACKAGE=\""grasslibs"\" -I/usr/include      -DPACKAGE=\""grasslibs"\"    -I/usr/include/ffmpeg/ -I/home/ddd/soft/grass-6.2.3RC1/dist.i686-pc-linux-gnu/include \
                -o OBJ.i686-pc-linux-gnu/gsd_img_ppm.o -c gsd_img_ppm.c
In file included from gsd_img_ppm.c:19:
/usr/include/ffmpeg/avcodec.h:2252: warning: ‘ImgReSampleContext’ is deprecated
/usr/include/ffmpeg/avcodec.h:2258: warning: ‘ImgReSampleContext’ is deprecated
gsd_img_ppm.c: In function ‘gsd_init_mpeg’:
gsd_img_ppm.c:122: error: ‘mpeg1video_encoder’ undeclared (first use in this function)
gsd_img_ppm.c:122: error: (Each undeclared identifier is reported only once
gsd_img_ppm.c:122: error: for each function it appears in.)
make: *** [OBJ.i686-pc-linux-gnu/gsd_img_ppm.o] Error 1
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=518&group_id=21
