[GRASS-dev] Unlimited precision
Francesco P. Lovergine
frankie at debian.org
Sun Oct 21 17:05:42 EDT 2007
http://www.nabble.com/ISO-C90-does-not-support-%60long-long%27-tf1038737.html#a2698581
About long long issue and other possible extension, I would promote the
use of GMP extended precision library, which is LGPL and largely used.
For instance it would be a nice solution for issues like:
http://wald.intevation.org/tracker/?func=detail&aid=493&group_id=21&atid=204
and indeed long long is already used in the code as you can see grepping
around.
