[GRASS-dev] [grass-code I][518] Problem compiling with ffmpeg
6.2.3RC1
Markus Neteler
neteler at fbk.eu
Sun Oct 21 17:05:38 EDT 2007
Glynn Clements wrote:
> grass-dev at grass.itc.it wrote:
>> code I item #518, was opened at 2007-10-21 22:05
> Known problem. The most recent versions of FFMPEG don't work with the
> 6.2.x code. It's fixed in 6.3-CVS; it's probably safe to back-port
> gsd_img_{ppm,mpeg}.c (you need both files).
I have copied both files to 6.2.CVS (incl. adding of gsd_img_mpeg.c to
branch).
This will appear in the next release candidate for 6.2.3.
Markus
View this message in context: http://www.nabble.com/-grass-code-I--518--Problem-compiling-with-ffmpeg-6.2.3RC1-tf4667111.html#a13333069
Sent from the Grass - Dev mailing list archive at Nabble.com.
