[GRASS-dev] bug in v.surf.bspline?
Roberto Antolín
roberto at geomatica.como.polimi.it
Mon Oct 22 14:55:10 EDT 2007
On Mon, 22 Oct 2007, Michael Barton wrote:
> Shouldn't the results be identical if the values used for interpolation are
> identical, regardless of whether they reside in the z-coordinate or an
> attribute?
Yes, the results must be the same, but only if there isn't another bug.
I'm completly sure about z-coord interpolation cos I use it daily.
However, since I don't use it with attributes values I don't know if it
works properly well. It should do so because the interpolation functions
are the same in both cases.
Obviously it works well to me, otherwise, I wouldn't have done the update
to cvs. However, till you don't do this last test I can't be sure. That
was what I wanted to mean, some caution. Sorry if I created some doubts.
It was no my intention.
> I'll test as soon as I have a chance and let you know.
Thank you very much, Michael. You are helping a lot for the module
bugfixing.
Roberto.
