[GRASS-dev] v.in.ogr parameter displays as optional instead of required
Patton, Eric epatton at nrcan.gc.ca
Wed Oct 24 14:28:18 EDT 2007
In v.in.ogr, the output parameter shows as 'optional' in the gis.m gui (6.3.cvs), when it's actually required:
$ v.in.ogr dsn=. type=point layer=Matthew_2007006_Nav_JD127_MinasChannel
ERROR: Required parameter <output> not set
Probably a simple swapping of words is all that's required?
~ Eric.
