[GRASS-dev] Re: [grass-code I][478] tcl/tk gui startup screen launches grass even when 'Exit' is pushed
Michael Barton michael.barton at asu.edu
Wed Oct 24 15:23:08 EDT 2007
On 10/24/07 4:27 AM, "Moritz Lennert" <mlennert at club.worldonline.be> wrote:
> On 24/09/07 19:55, grass-dev at grass.itc.it wrote:
>> code I item #478, was opened at 2007-09-07 15:40
>>> Status: Open
>> Priority: 3
>> Submitted By: Moritz Lennert (moritz)
>> Assigned to: M?ris Nartišs (marisn)
>> Summary: tcl/tk gui startup screen launches grass even when 'Exit' is pushed
>> Issue type: other bug
>>> Issue status: confirmed
>> GRASS version: CVS HEAD
>> GRASS component: startup
>> Operating system: Linux
>> Operating system version:
>> GRASS CVS checkout date, if applies (YYMMDD): 070903
>>> Comment By: Maciej Sieczka (msieczka)
>> Date: 2007-09-24 19:55
>> Message:
>> The issue is more complicated. According to Paul Kelly the committed fix is
>> not complete. See Details Below:
> Where are we at with this issue ? At this point it is still not solved
> for wingrass and for other platforms I don't know if the solution
> currently in CVS for init.sh is deemed satisfactory.
> Moritz
It works fine for me with Mac OS X in GRASS 6.3
Michael
>> Paul Kelly wrote on GRASS dev ML:
>>> I think it's a good idea to change the behaviour here,
>>> but I feel the patch doesn't really address the problem:
>>> rather it adds more code to work around it. In
>>> particular, clicking exit in the gis_set.tcl Window won't
>>> work with init.bat (Windows) now, as it used the exit
>>> code of 1 to indicate exit (whereas the patch makes an
>>> exit code of 2 now indicate exit). I notice also the
>>> patch makes the exit code of the Python version of
>>> gis_set.tcl be interpreted differently - has anybody
>>> checked what effect this will have?
>>> The problem is the historical behaviour that an error in
>>> gis_set.tcl (e.g. the wrong version of Tcl/Tk) caused it
>>> to drop out from attempting the GUI startup but go ahead
>>> and start an interactive GRASS shell. When I made a few
>>> changes to the return codes from gis_set.tcl I
>>> deliberately avoided tackling this because I wasn't sure
>>> what was the best solution. But on thinking about it
>>> more, I think dropping to an interactive shell is the
>>> wrong approach. It should print a warning/error message
>>> and then exit, and if the user wants to start in
>>> text-based mode instead they can use the -text switch
>>> next time round.
>>> init.bat assumes a return code of 1 means exit. I vaguely
>>> intended the same interpretation for Init.sh, and to
>>> remove the facility to drop to an interactive shell when
>>> there was an error in gis_set.tcl, but I didn't implement
>>> this nor tell anybody about my plans: my fault ;)
>>> I think it would simplify things if we made Init.sh
>>> always exit when a non-zero exit code is returned from
>>> gis_set.tcl- any other thoughts? (I should probably
>>> update init.bat too so it goes ahead when 0 is returned,
>>> rather than exiting when 1 is returned).
>> You can respond by visiting:
>> http://wald.intevation.org/tracker/?func=detail&atid=204&aid=478&group_id=21
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
