[GRASS-dev] db.execute: ".execute" suffix missing in man page
Wed Oct 24 15:49:49 EDT 2007
Paul Kelly wrote:
> >> In Firefox and Lynx browsers the ".execute" part of
> >> "db.execute" is missing above the module description. It
> >> also not there in "man db.execute" output.
> > G_parser() does:
> > 	G_basename(tmp_name, "exe");
> Oops - that was an oversight on my part.
> > G_basename() is described thus:
> > * \fn char * G_basename (char *filename, const char *desired_ext)
> > * \brief Truncates filename to the base part (before the last '.')
> > * if it matches the extension, otherwise leaves it unchanged.
> > But it actually only checks if the specified extension is a prefix of
> > the actual extension rather than a complete match.
> The reason for that was so that e.g. "tif" can match .tif and .tiff and
> other usage cases like that. The original usage for G_basename() was
> checking the output filename for r.out.tiff so it could decide if it
> should add an extension or not.
> > Suggested fix (untested):
> > char * G_basename(char *filename, const char *desired_ext)
> >    /* Find the last . in the filename */
> >    char *dot = strrchr(filename, '.');
> >    if (dot && G_strcasecmp(dot + 1, desired_ext) == 0)
> >       *dot = '\0';
> >    return filename;
> That would break the way it is used in r.out.tiff in some circumstances.
> I'm thinking it might be easier to conditionalise its use in G_parser()
> and G_set_program_name() on __MINGW32__ as its only purpose there is to
> strip out the .exe executable extension on Windows?
> Maybe there should be two functions though. Or maybe stripping out the
> .exe is quite simple and it doesn't need to use G_basename()?
> If noone else has fixed this yet I'll try and get to it fairly soon.
I suggest fixing G_basename() as above; the current behaviour is
counter-intuitive and undesirable in most cases.
r.out.tiff should check for .tif and .tiff separately. This isn't just
a matter of being able to use G_basename() for other purposes.
r.out.tiff shouldn't treat anything other than .tif or .tiff (modulo
case) as a TIFF extension; cf. "area.around.Tifton_GA".
