[GRASS-dev] GRASS 6.3.0RC1 released
Carlos Dávila
cdavilam at jemila.jazztel.es
Thu Oct 25 16:37:53 EDT 2007
Hamish escribió:
> Some pedantic but by my experience useful steps added below,
> (lessons learned as I messed things up at each one of these steps in the past)
> Glynn wrote:
>> To clarify:
> 0. 'cvs update' to be sure you are working with the latest version.
>> 1. Make changes to the local copy of the trunk.
> 1.5 'cvs diff' to check for left over temporary debug messages, unnecessary
> whitespace changes, etc.
>> 2. Commit the changes.
> 2.5. Decide if the change is suitable for backporting.
>> 3. Change directory to the local copy of the branch.
>> 4. Use "cvs update -j ... -j ..." to synchronise the branch to the
>> trunk.
> 4.5 'cvs diff' check again.
>> 5. Commit the changes.
Perfectly clear now, thanks both of you
> As to deciding what is suitable for backporting, I am of two minds. On one hand
> it is very useful to have some sort of deadline to motivate us to fix as many
> old lingering bugs as possible before the release. On the other hand even small
> modifications to critical modules like g.region and r.out.gdal days before
> release are very dangerous. Those need maximum testing time in the development
> branch to avoid nasty unintentional side effects. It has been typical for that
> sort of mistake not to be spotted even in the well tested CVS/HEAD version for
> months.
> A good rule seems to be only backport important bug fixes and well-tested
> important updates. Leave anything else to a future release. 6.3.0 is not
> intended to be as stable as 6.2, so I wouldn't worry so much about that here,
> for 6.3 it becomes more a question of if the backporting justifies the double
> effort.
My changes only affect internationalized messages, so they neither fix
important bugs nor should create them, so the effort is the only thing
in mind.
Thanks again for the information.
Carlos
