[GRASS-dev] wingrass: etc/fontcap contains fonts from dist. directory not installed directory
Thu Oct 25 17:28:45 EDT 2007
Moritz Lennert wrote:
> >> The grass-6.3.cvs/etc/fontcap file in wingrass contains a series of
> >> entries of the sorts:
> >> cyrilc|Cyrillic|0|c:\grasssrc\grass6\dist.i686-pc-mingw32\fonts\cyrilc.hmp|0|utf-8|
> >> This should be
> >> cyrilc|Cyrillic|0|c:\grass\grass-6.3.cvs\fonts\cyrilc.hmp|0|utf-8|
> >> IIUC, the line that deals with this in the Makefile is (277):
> >> -sed 's#'${GISBASE}'#'${INST_DIR}'#g' ${GISBASE}/etc/fontcap >
> >> ${INST_DIR}/etc/fontcap
> >> Do we need an equivalent line for wingrass with WINGISBASE ?
> > WINGISBASE doesn't exist during compilation. AFAICT, it's only used
> > within grass63.bat and init.bat.
> Duh, obviously it has nothing to do with WINGISBASE. The problem is path
> syntax:
> content of dist.i686-pc-mingw32/etc/fontcap:
> cyrilc|Cyrillic|0|c:\grasssrc\grass-6.3.0RC1\dist.i686-pc-mingw32\fonts\cyrilc.h
> mp|0|utf-8|
It's sort of related to WINGISBASE; if you run the installation
in-place, WINGISBASE would be set to:
which would work. But WINGISBASE isn't set while building, only when
actually running GRASS.
> sed command in the Makefile:
> which during install translates to
> sed
> 's#'/c/grasssrc/grass-6.3.0RC1/dist.i686-pc-mingw32'#'c:/grass63RC1/grass-6.3.0RC1'#g'
> /c/grasssrc/grass-6.3.0RC1/dist.i686-pc-mingw32/etc/fontcap >
> c:/grass63RC1/grass-6.3.0RC1/etc/fontcap
> fontcap entries need to use windows syntax under windows for gis.m to see
> the font.
It's more than just gis.m; C functions (e.g. fopen()) only understand
Windows syntax, not MinGW/MSys syntax. Forward slashes work in most
places (but not in the command interpreter), so either c:/grass63RC1
or c:\grass63RC1 will work, but /c/grass63RC1 won't.
> So, we need a specific sed command for windows, but do we have a variable
> for GISBASE in windows path syntax ? If not how to create it ?
> > Or, you can always regenerate the fontcap file after installation.
> That's what I'm doing manually now for the binaries, but it would be great
> to have this to happen automatically. Is this possible in the Makefile ?
g.dirseps will convert the separators, but not the /c/ -> c:/ for the
drive letter.
Does $(RUN_GISBASE) have the correct syntax?
