[GRASS-dev] Cairo monitor driver
Lars Ahlzen lars at ahlzen.com
Thu Oct 25 18:01:15 EDT 2007
Glynn Clements wrote:
>> Good point. It makes sense to set the default line width to 1 unit, at
>> the very least for PNG output, to make sure it's consistent with the
>> behavior of other pixel-based monitors.
> Note that you cannot get consistency with XDRIVER; X intentionally
> doesn't specify the rendering of thin (zero width) lines, so that a
> hardware implementation can be used. IOW, zero width lines are
> rendered however the graphics chip decides to render them.
X may be an exception in that respect. Then again, have you ever used a
system that didn't render them as 1 pixel lines? ;-)
>> Anyway, assuming that the default line width is 1 unit for pixel based
>> output (to be consistent), then the problem remains.
> At this point, it's largely moot.
> Integrating the cairo driver (e.g. modifying libraster to allow direct
> rendering via the cairo driver) is probably too destabilising a change
> now that 6.3 is at the release-candidate stage, so gis.m will likely
> continue to use the PNG driver.
It may be moot with respect to 6.3.
I just want to make the driver as useful as possible. Since I still
don't see any downside implementing the offset (other than a few extra
lines of code), but a significant benefit, I see no reason not to do so.
It's by no means urgent, though.
> 7.x will use floating-point display coordinates throughout, so there
> will be no need for any offset.
True. This will be very nice indeed! Btw, do we expect more 6.x releases
after 6.3, or will all work shift to 7.x?
/ Lars
Lars Ahlzen
lars at ahlzen.com
