[GRASS-dev] some backports to 6.3.0-CVS branch
Glynn Clements
glynn at gclements.plus.com
Fri Oct 26 17:33:04 EDT 2007
Benjamin Ducke wrote:
> > Using a recursive make should fix it:
> > --- lib/vector/rtree/Makefile 19 Oct 2007 13:45:53 -0000 1.10
> > +++ lib/vector/rtree/Makefile 26 Oct 2007 09:28:19 -0000
> > @@ -15,9 +15,8 @@
> > HEADERS := $(RTLINC)/card.h $(RTLINC)/index.h $(RTLINC)/split_q.h \
> > $(ARCH_INCDIR)/rtree.h
> > -default: lib
> > -lib: $(HEADERS)
> > +default: $(HEADERS)
> > + $(MAKE) lib
> > $(RTLINC):
> > $(MKDIR) $@
> Sorry, but this still results in:
> make: *** No rule to make target
> `/src/grass6/dist.i686-pc-mingw32/include/grass/rtree/card.h', needed by
> `default'. Stop.
> (the only difference being that make now bails out before compiling
> any objects in rtree).
Okay, that's a different issue. I have no idea what, though; the
required rule is quite definitely there.
> > What happens if you enter the following directly into the shell?
> > if [ "" != "" ] ; then for dir in ; do make -C $dir clean ; done ; fi
> sh: syntax error near unexpected token `;'
I don't think that there's much can be done there; you'll just have to
live with the noise.
