[GRASS-user] RE: [GRASS-dev] r.in.xyz can now read from stdin
Patton, Eric
epatton at nrcan.gc.ca
Thu Oct 25 10:56:55 EDT 2007
>> Hamish:
>>> I just added redirection from stdin support to r.in.xyz. Everything
>>> seems to work, but of course testing is appreciated.
> Eric wrote:
>> Thanks very much for this. I've tested r.in.xyz on a massive Simrad
>> EM710 swath bathymetry dataset. Results follow:
<snip>
>> The newly-gridded bathy looks fine; identical to the original.
> r.univar results the same? (n and sum)
> or
> r.mapcalc diff_map=old-new
> r.univar diff_map
Hamish:
> maybe we need a r.md5sum option added to r.info?
I finally got around to running some long overdue r.univar comparisons between a bathymetry dataset exported from
r.out.xyz and stdin'd to r.in.xyz:
~/Projects >g.region -pg
n=5030730
s=5006690
w=372650
e=404020
nsres=10
ewres=10
rows=2404
cols=3137
cells=7541348
~/Projects >r.out.xyz input=Matthew_2007006_AllBathy_10m.grd | r.in.xyz input=-
output=testing_r_in_xyz
~/Projects >r.univar -g map=Matthew_2007006_AllBathy_10m.grd
n=2497361
null_cells=5043987
min=-171.591
max=-8.47771
range=163.113
mean=-46.3785
mean_of_abs=46.3785
stddev=21.4064
variance=458.235
coeff_var=-46.1559
sum=-115823957.9045209885
~/Projects >r.univar -g testing_r_in_xyz
n=2497361
null_cells=5043987
min=-171.591
max=-8.47771
range=163.113
mean=-46.3785
mean_of_abs=46.3785
stddev=21.4064
variance=458.235
coeff_var=-46.1559
~/Projects >r.mapcalc diff_map = 'Matthew_2007006_AllBathy_10m.grd -
testing_r_in_xyz'
~/Projects >r.univar -g diff_map
n=2497361
null_cells=5043987
min=0
max=0
range=0
mean=0
mean_of_abs=0
stddev=0
variance=0
coeff_var=nan
sum=0
Looks pretty good to me!
Thanks again,
Eric Patton
Technologist
Geological Survey of Canada (Atlantic)
Bedford Institute of Oceanography
Dartmouth, Nova Scotia, Canada
902.426.7732
grassuser mailing list
grassuser at grass.itc.it
http://grass.itc.it/mailman/listinfo/grassuser
