[GRASS-dev] r.terraflow license
nicholas.g.lawrence at mainroads.qld.gov.au
Mon Oct 29 20:26:27 EDT 2007
> > Brad Douglas wrote:
> > However, we may want to augment the
> > statement to say "(v2)" instead of, "(>=v2)". GPLv3 exists and there
> > has been no consensus on using it (although, the GRASS statement
implies
> > we already do).
> Glynn Clements
> If we were to remove the "or any later version" text, we would quickly
> forfeit the right to subsequently adopt a later version, as any
> contributions would be assumed to be licensed under "v2 only" terms.
> If we ever wanted (or needed[1]) to adopt a later version, we would
> have to obtain explicit consent to do so.
One option is for authors to donate their code to a foundation (is there
a GRASS foundation or trust?) that has the power to re-release the code
under an appropriate liscence. This way, if something unfortunate were
to happen to an author, the foundation would be able to gracefully handle
software liscencing issues in the future.
nick
WARNING: This e-mail (including any attachments) may contain legally
privileged, confidential or private information and may be protected by
copyright. You may only use it if you are the person(s) it was intended
to be sent to and if you use it in an authorised way. No one is
allowed to use, review, alter, transmit, disclose, distribute, print
or copy this e-mail without appropriate authority.
If this e-mail was not intended for you and was sent to you by mistake,
please telephone or e-mail me immediately, destroy any hardcopies of
this e-mail and delete it and any copies of it from your computer
system. Any right which the sender may have under copyright law, and
any legal privilege and confidentiality attached to this e-mail is not
waived or destroyed by that mistake.
It is your responsibility to ensure that this e-mail does not contain
and is not affected by computer viruses, defects or interference by
third parties or replication problems (including incompatibility with
your computer system).
Opinions contained in this e-mail do not necessarily reflect the
opinions of the Queensland Department of Main Roads, Queensland
Transport or Maritime Safety Queensland, or endorsed organisations
utilising the same infrastructure.
