[GRASS-dev] gis.m freeze
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Wed Oct 31 05:28:52 EDT 2007
I have no clue why - but I deleted .grassrc6 and .grasslogin6 from my home
directory and grass6.3 and 6.2 GUIs are working again.
Martin
On Tuesday 30 October 2007 13:37:04 Martin Wegmann wrote:
> On Monday 29 October 2007 16:54:41 Martin Wegmann wrote:
> > Hello,
> > I just update cvs again and encountered a freezing gis.m (see png for
> > error prompt - I had to kill gis.m) - exexuting d.rast, d.mon etc.
> > without problems but not gis.m.
> > moreover the g.copy "memory access" bug is still/again present - but I
> > think it has been discussed in the past - solved with:
> > make -C general/manage clean
> > make -C general/manage CFLAGS1='-g'
> > using debian unstable, tcltk 8.4 and cvs 6.3 update
> > (./configure --with-tcltk-includes=/usr/include/tcl8.4
> > --with-postgres-includes=/usr/include/postgresql
> > --with-gdal=/usr/local/bin/gdal-config --enable-largefile )
> to figure out if it is a GRASS or rather system related problem, I
> installed grass6.2.3RC1 from the GRASS page and when starting grass62 I
> get:
> GRASS 6.2.3RC1 (spearfish60):~ > D2/5: G__read_Cell_head
> D2/5: G__read_Cell_head_array
> D3/5: region item: proj: 1
> D3/5: region item: zone: 13
> D3/5: region item: north: 4928010
> D3/5: region item: south: 4913700
> D3/5: region item: east: 609000
> D3/5: region item: west: 589980
> D3/5: region item: cols: 634
> D3/5: region item: rows: 477
> D3/5: region item: e-w resol: 30
> D3/5: region item: n-s resol: 30
> D3/5: region item: top: 1
> D3/5: region item: bottom: 0
> D3/5: region item: cols3: 634
> D3/5: region item: rows3: 477
> D3/5: region item: depths: 1
> D3/5: region item: e-w resol3: 30
> D3/5: region item: n-s resol3: 30
> D3/5: region item: t-b resol: 1
> Error in startup script: can't read "monitor_zooms(1,1,n)": no such
> variable while executing
> "lappend region $monitor_zooms($mon,1,$attr)"
> (procedure "MapCanvas::currentzoom" line 13)
> invoked from within
> "MapCanvas::currentzoom $mon"
> (procedure "MapCanvas::coordconv" line 23)
> invoked from within
> "MapCanvas::coordconv $mon"
> (procedure "MapCanvas::create" line 68)
> invoked from within
> "MapCanvas::create"
> (procedure "Gm::startmon" line 11)
> invoked from within
> "Gm::startmon"
> (procedure "Gm::create" line 69)
> invoked from within
> "Gm::create"
> (procedure "main" line 30)
> invoked from within
> "main $argc $argv"
> (file "/usr/local/grass-6.2.3RC1/etc/gm/gm.tcl" line 521)
> due to a similar problem with my 6.3-cvs installation, I assume that it
> might be related to some debian unstable issues - any clue which package I
> have to update/remove?
> Martin
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
