[GRASS-dev] Wingrass and TclTk
Wed Oct 31 11:36:11 EDT 2007
Benjamin Ducke wrote:
> > The scripts use a lot of common Unix utilities; have you included
> > those? If they need to read any data files, are they looking for them
> > in the WinGRASS directory or in the already-installed version of
> > MSys/MinGW?
> Yes, I made a complete install of MSYS + tools and just copied
> everything over. I was going to look through it later to check
> what can be thrown out and bit by bit make a list of what needs
> to go in.
> The wingrass.bat script I posted early starts up cmd.exe in the user's
> Windows home directory. Sh.exe also respects that. Thus, scripts look
> for files in the user home dir first.
> Which I think is OK.
I'm talking about cases where the executable needs to open files in
/etc, /usr/lib, /usr/share, etc. I'm guessing that the executable
isn't going to be expecting "/" to be wherever you put GRASS.
