[GRASS-dev] Re: [GRASS-user] GRASS6.3 on Windows
Paul Kelly paul-grass at stjohnspoint.co.uk
Sun Sep 2 08:28:40 EDT 2007
On Sun, 2 Sep 2007, Glynn Clements wrote:
> Maris Nartiss wrote:
>> Alltough Glynns suggestion about redirecting GRASS error messages ALSO
>> to some error.log file would be a good idea as this file could be a
>> must for (crash) bug reporting. Only as a non-programmer I see some
>> difficulties:
>> 1) How multiple processes (modules) can append data to that file in sane way;
>> 2) When enable such functionality? I.E. g.env set=ERRLOG=true
>> 3) What else needs to be written to such file? I.E. command history,
>> arch, GRASS version...
> I wasn't talking about writing to a "log" file, but a temporary file
> which would be used for a single command.
> The problem is that Tcl's "exec" command considers it an error if a
> subprocess writes anything to stderr. However, a number of modules
That's true - however the error-detecting code in file_option.tcl doesn't
use the return value of catch to determine whether an error has occured or
not - instead it checks the global variable errorcode to see if the
command just run has exited with an error or not.
e.g. something like this:
catch {exec g.proj -c georef=$filepath location=$fileLocation} errMsg
if {[lindex $::errorCode 0] eq "CHILDSTATUS"} {
# Pop-up error dialog here.
It seems to work well but perhaps mightn't cover all eventualities?
Paul
